Re: Bars leaks stop leak tablets
Posted by rhtx55 on February 12, 2014 at 16:02:21 from (68.185.207.25):
In Reply to: Bars leaks stop leak tablets posted by Patrick HMD on February 10, 2014 at 19:30:14:
The pitted area in the photo would be an excellent place to use JB Weld. Clean the area first to remove any & all rust, mix it up & apply. File it down smooth when cured & re-install the cover. Check the bolt flanges in the cover to be sure they are not "dimpled" in from someone over tightening in the past. If so carefully bring back to straight & level using a pair of ball peen hammers on a sturdy flat surface such as an anvil or large vise.
