Re: FCUB clutch problem
Posted by Janicholson on February 12, 2014 at 17:03:43 from (74.60.94.18):
In Reply to: FCUB clutch problem posted by john obar on February 12, 2014 at 13:56:46:
Guessing!
The disk in backwards causes the pressure plate to touch it too soon as the Pressure plat bolts are tightened. This causes the "effective" thickness of the plate to be 1/3 or more thicker as the torsion springs press against the flywheel. THe release levers are pulled way in toward the flywheel and become over center.
The free play is then adjusted (a lot) to account for this wrong finger position.
When started, the clutch does not even begin to disengage, and the throwout pushes through the fingers crashing them into the bearing carrier and ripping things up.
Not good. Jim
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
