Re: Farmall A stuck
Posted by ken house on February 12, 2014 at 18:54:28 from (173.242.240.188):
In Reply to: Farmall A stuck posted by tlc28 on February 12, 2014 at 17:38:33:
did not understand how long engine has been stuck. i have unstuck 1. take the spark plugs out. use compressed air and blow as much as you can from the cylinders. do this a couple of times over a couple of days. oil floats on water, so water has to come out before penetrant can work. remove starter. after soak for a few days, stick big screwdriver into starter hole and prize both ways, try to rock the engine. if still stuck. remove oil pan place jack under rod journal, place block of wood on top of jack, and raise the tractor, clear the front wheels. at this point, i placed a screwdriver in the starter hole and prized and it came loose.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
