Re: T/A vs Multi-Power
Posted by mkirsch on February 13, 2014 at 10:05:27 from (65.199.189.6):
In Reply to: T/A vs Multi-Power posted by Phil in Pa on February 13, 2014 at 03:32:37:
There are two types of TA, mechanical and hydraulic.
Mechanical TA does not hold back in low range. Tractors with mechanical TA generally have a long lever coming up from the left side of the platform above the brake drum, with a squeeze handle to release it. Exceptions are the 544, 656, 666, and 686, which have a short TA lever on the steering console like the hydraulic TA models.
Hydraulic TA holds back in low range, if it is installed and adjusted properly. 06, 56, 66, and 86 series tractors with numbers starting with a 7, 8, 9, 10, 12, 14, or 15 can be equipped with a hydraulic TA. Also 3X88 and 6X88 series tractors. Hydros do not come with TAs.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
