Re: Weight of tire and wheel
Posted by Zachary Hoyt on February 14, 2014 at 06:50:37 from (74.47.52.192):
In Reply to: Weight of tire and wheel posted by Fudd on February 13, 2014 at 19:06:18:
Very heavy. The exact weight would depend partly on the strength of the calcium solution. Don't let it fall on you. I swapped loaded 14.9/38s onto my H and then onto my 300 by hand. I parked the tractor close to the wall and that way I could roll the tire and if it tipped it could either lean on the wall or on the tractor before it fell over all the way. Then I could get it back up again.
Zach
