Posted by djhammerd on February 14, 2014 at 16:20:53 from (173.66.69.90):
I just purchased what I thought was a IH Little A Super. The serial number plate that is supposed to be on the seat bracket is missing. I would like help determining exactly what I have.
There are two numbers (cast) on the chassis (right side, operator view) that I think may help with identification.
One is high on the chassis, just under the fuel tank behind two hydraulic lines. That number is 354352. 1.24.J follows that number
The second number is cast low on the chassis down and a little to the left of the number above. This number is 351687-R4.
Other significant information.... There is a water pump behind the fan.
There is also (and I don't know if this is a modification by some owner), a spacer (about 1.25 inches showing) between the sheet metal covering the radiator and the sheet metal covering the engine. It is put on with pop rivets.
Thanks in advance for any information you may provide...
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
[More Ads]
