Re: T/A vs Multi-Power
Posted by Jon Hagen on February 14, 2014 at 16:47:36 from (69.26.17.61):
In Reply to: T/A vs Multi-Power posted by Phil in Pa on February 13, 2014 at 03:32:37:
The Hydraulic TA has a little wet clutch added to low range to allow engine braking, instead of freewheeling through the low sprag clutch. This little clutch is fine when used as intended, but the fellow who is running 20 mph with a heavy load behind and uses low TA as an engine brake constantly instead of using the wheel brakes can destroy that little clutch in one afternoon.
