I've got the same setup 400 with 15.5s a single weight and calcium and from my experience NEVER get beside the tire, put your strap on the tire with a little slack Jack the axle just enough so the tire is barely touching the ground and put enough air in it so it doesn't squash much get four strong guys two on each END and jiggle it off then use your loader to move it around and you want as little distance as possible between the tire and loader so it can't swing a lot and if your tire is flat fix it or change it while it's still on the tractor
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
