The internal attachment seems to be only the setscrews you indicate. Were it mine I would use a die grinder to groove out the original weld and then (using pulses of weld (wire welder on spot weld setting) or short touches of weld with a small diameter rod and good chipping) weld the tab back on. If the grease fitting is located in the end of the shaft, it may stay clear enough to allow greasing with a rubber tipped grease injector rather than a zerk. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
