Re: Conversion of a Super A to 12 Volt.
Posted by mkirsch on February 15, 2014 at 14:27:44 from (65.199.189.6):
In Reply to: Conversion of a Super A to 12 Volt. posted by djhammerd on February 15, 2014 at 13:22:54:
If you get a one-wire alternator, there are only two things you need to do to wire it up on a Super A:
1. Remove the wires from the BAT terminal on the regulator, and attach it to the BAT terminal on the alternator. If there is a wire on the "L" terminal of the regulator, move it to the BAT terminal on the alternator too.
2. Swap the wires from one post of the ammeter to the other.
Like that, it will charge and show it correctly on the ammeter.
