Re: Super M Transmission
Posted by D Slater on February 15, 2014 at 15:48:07 from (184.14.164.129):
In Reply to: Super M Transmission posted by JStoff on February 15, 2014 at 09:56:28:
If wanting to change just some gears another SM or a SW6 is all that will work. If changing the input shaft that the 4th and 5th sliding gear locks to for 5th. Later M is the same. Previous M will work if you also use the M input shaft bearing housing. But they have a smaller front bearing that supports the input shaft than a late M or SM. M first sliding gear is the only gear that will interchange in a SM transmission if nothing else is changed over.
