Posted by Larry B. 1486 on February 16, 2014 at 07:20:39 from (72.106.59.250):
In Reply to: IH 1190 cutter posted by Gary in Indy on February 15, 2014 at 19:14:29:
Gary. I had a IH 1190 9ft conditioner for about 20 years. What that is for when you make short turns it lets the cutter swing to the side more so the PTO is not having to make a hard bend to keep the U joints from chattering. I can't remember just how it attached to the drawbar, I know mine had one bolt thru it, but I only used that piece for a year or two. I just ran it with a pin with a nut on the bottom thru the drawbar on the tractor an the cutter tongue with the hole on it. If you have a hammer strap on your tractor, that will work also and not use the this part you have pictured.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
