Re: 1945 Farmall M Vapor Lock
Posted by Baelee05 on February 16, 2014 at 08:14:02 from (12.192.13.220):
In Reply to: Re: 1945 Farmall M Vapor Lock posted by Allan In NE on February 16, 2014 at 07:56:47:
Allan is 100% correct. Vapor locking was a somewhat common problem on cars 30 or 40 years ago. Since then it has become a common excuse for an engine that won"t start used by those who have no clue what they are talking about. There are a lot of things that might be causing your old M not to run but vapor locking is not one of them. No offense to your old timer friend. If you have compression, fuel, and spark, it almost has to run. It sounds like you have plenty of fuel to the carb but is your carb functioning properly? Double check the status of your ignition system by following some of the procedures outlined by others. If carb and ignition check out you are left with compression. The fact that the tractor does not even try to fire leads me to believe you have an ignition problem.
