Use a volt meter to see if there's voltage to your coil when your ignition switch is in the on position. If there's no voltage check your ignition switch to see if there's voltage being fed to the switch. Check for voltage on the switch terminal to your coil when its in the on position. If there's no voltage present you need a new switch and if have voltage replace the wire from the switch to your coil. Hal
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
