Re: 52 H farmall will a stuck break hold up both sides
Posted by farmaller on February 17, 2014 at 05:21:43 from (184.6.13.130):
In Reply to: 52 H farmall will a stuck break hold up both sides posted by wcochran on February 16, 2014 at 19:45:45:
Could be starter is locked with ringgear too, loosen bolts and see if it pops loose
