Re: 52 H farmall will a stuck break hold up both sides
Posted by mkirsch on February 17, 2014 at 07:51:43 from (65.199.189.6):
In Reply to: 52 H farmall will a stuck break hold up both sides posted by wcochran on February 16, 2014 at 19:45:45:
No on the brake. One locked up brake will only hold up one side.
Either the tractor is stuck in two gears at once, or the water in the rear end has finally frozen solid.
