Re: 1086 TA
Posted by mkirsch on February 17, 2014 at 08:28:22 from (65.199.189.6):
In Reply to: 1086 TA posted by Russell Moore on February 17, 2014 at 07:27:33:
Either way you'll only do the job once in your lifetime.
A functional TA will make the tractor more valuable and useful.
Contrary to popular belief, the TA is not a "problem area." The newest 1086's are 33 years old, and most have seen seriously heavy use. It's just plum wore out from normal use.
BTW, the hydraulic TA on a 1086 will *NOT* "run forever in high" if the low side is out. That only works for mechanical TAs.
On a hydraulic TA, if one side is out, the other is not far behind.
