Posted by D Slater on February 17, 2014 at 10:33:18 from (184.14.172.163):
In Reply to: International 300 posted by tractortracer on February 17, 2014 at 00:14:28:
Just to make sure we are referring to the same plug. Its the one near the bottom of the bowl pointed to the front of tractor when mounted on the engine. 361525R91 is a gasoline carburetor installed on early 300 tractors. 361525R92 is a gasoline carburetor installed on other 300 and on 350 tractors.
361525R92 came with a adjusting screw and nut and a few other changes in metering compared to a 361525R91.
Sometime in 1955 IH had a service bulletin that they wanted all the 361525R91 carburetors changed to R92. Enough change over kits with instructions were made to change over all R91 carburetors sold.
Some never were changed and one shows up ever now and then. Also find some changed without the ID number tag changed.
If yours runs okay don't worry about it. Mostly done for supposedly better fuel economy.
Those carburetors used a idle jet with a .021 orifice hole. Most M came with a .025 hole. Think H used one in between. Don't hold me to the sizes since just going by memory. Could look if needed. May be able to use any of the sizes and adjust the idle air to compensate, depending on other variables .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
