Posted by JimB2 on February 17, 2014 at 13:47:32 from (99.240.243.222):
In Reply to: Hydro 84 posted by Dieseltech on February 17, 2014 at 06:57:34:
Hi Dieseltech,
Yes, looking at parts book the Hydro 84 appears to have same PTO setup as 684/784. My brother had a 1000 RPM PTO installed in his 495. It took CasIH mechanic about 1 hour to do the job.
From archives: Installing 1000 RPM PTO: Hi TWafer and JB2, you have to buy the 1000 rpm PTO shaft, the cover with a hole and a seal. Remove the shaft, by removing the spring pin that holds it in the PTO clutch pack, and the rear cover. Place the 1000 rpm PTO shaft in place, secure with the spring pin and bolt the cover. That's it. Bernard le mécano Québec Canada
Hi TWafer, yes, you remove the pin by the right round cover. Hold the clutch pack when you pull on the shaft. Make sure to align carefully the shaft with the clutch pack before you press the spring pin. Bernard le mécano Québec Canada
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
