Re: IH 2001 Loader on 300
Posted by Brendon-KS on February 17, 2014 at 19:09:53 from (63.245.147.52):
In Reply to: Re: IH 2001 Loader on 300 posted by Stemmy on February 17, 2014 at 17:02:47:
According to my old IH literature both the 2000 and
2001 had 2" bore single-acting lift cylinders as
standard with 2.5" double-acting as optional. You
can identify the double-acting version by the steel
oil line running down the underside of the barrel
to a port on the rod end cap. The single-acting
ones will only have a hose going to the base end
(which is at the top when installed on the loader).
