Re: calling...Al L in Wisc
Posted by Al L. in Wisc. on February 17, 2014 at 19:18:04 from (216.226.92.254):
In Reply to: calling...Al L in Wisc posted by Kirk Affeldt on February 17, 2014 at 17:26:36:
Kirk Affeldt; do you know if that 2001 specifically was on a Farmall 340? The rear mounting of the IH sub-frame and the front mounting brackets are 340 specific.
I am sure folks will state that if you have a welder or know someone who does, you can make it work; yes, but not original. That maybe isn't of any concern to you.
No power steering = big problem. I called coast-to-coast and filled ~ seven pages with numbers looking for same for several years = no luck. As Putter says, you will most likely need to find a 'donor' 340. For the hydraulics, an aftermarket single or aftermarket twin cylinders can be added if you have the remotes on your tractor.
Depending on your purpose for a loader, a heavy load can really strain the front end.
You probably already know this but, there was an optional tine cover, material bucket and snow bucket for the IH loader. My Farmall 340 with factory utility swept back front axle WITHOUT power steering is staying that way. I really don't have a use for one and no power steering, well.....
Regarding cost, ?? Steel lines, fittings, hose(s) if you need them, do add up; but a loader can save on your back as well. I wish you luck with your project. Many good folks on this board really love their 340's. More knowledgeable folks will probably chime in so watch your post.
