Re: Farmall C Steering Gear Box - Oil Level
Posted by Stemmy on February 18, 2014 at 17:29:54 from (206.49.63.193):
In Reply to: Farmall C Steering Gear Box - Oil Level posted by C. Amick on February 18, 2014 at 17:19:11:
more than likely its the drain plug. drain it and fill the gearbox with some good tacky grease. that way you dont have to worry about it making a mess if it ever leaks.
