Noise in Neutral can be from a variey od sources. The most important info is what the noise sound like. Fromt input shaft bearings, Intermediate (pilot shaft) bearing, Counter shaft bearings, and the constant mesh gears are all in motion. When in forward gears (except 5th) there is pressure on the gears/bearings that might cause less noise. reverse is inhearently more noisy than the others as it has an idler to go through as well. Give us a sound. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
