Re: Conversion of a Super A to 12 Volt.
Posted by Owen Aaland on February 19, 2014 at 13:38:15 from (216.47.35.218):
In Reply to: Conversion of a Super A to 12 Volt. posted by djhammerd on February 15, 2014 at 13:22:54:
Delco-Remy did make a one wire regulator for the larger alternators that fits in the 10SI so it is a simple matter to build one using all Delco parts.
The one wire alternators that I have assembled have all fallen into the the rpm range of 1100 - 2600 to self energize. Generally the higher the amperage output the higher the speed need needed to self energize. I just try to match the lower rpm ones to tractors that have lower rpm engines to eliminate some of the kick in problems.
