Re: Ring and pinion questions
Posted by Gerry Powell on February 19, 2014 at 16:51:47 from (173.172.83.6):
In Reply to: Ring and pinion questions posted by Taylor88 on February 19, 2014 at 08:48:10:
I can't answer if it would work in a 560.
Since your ratio is 47:19 (2.47) is the lowest ratio, changing to both higher ratios will decrease your speed at the same engine RPM. The 50:19 gears will decrease your speed by 6% and the 49:15 gears will reduce your speed by 24%
