Re: Super A Starting Problems
Posted by djhammerd on February 19, 2014 at 17:22:51 from (173.66.69.90):
In Reply to: Super A Starting Problems posted by Janicholson on February 19, 2014 at 16:48:11:
Janicholson said: (quoted from post at 17:48:11 02/19/14) Did you clean and gap the points? Did you pull the plugs and heat them with a propane torch then reinstall? Did you try putting WD40 (a 1/2 second spritz) in each hole before putting the warm plugs back in? Did you try pull starting it? Jim
I did clean and gap the points. I can try warming the plugs and using WD40 tomorrow.
I can't really pull the tractor until the snow is gone and it dries up a bit (maybe next week). That will tell me if faster turning-over will help.
All good ideas. Thanks!
I think I may move the ground cable over to a bolt on the starter also, just to be more direct for the troubleshooting.
This post was edited by djhammerd at 17:25:04 02/19/14.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
