Re: Super A Starting Problems
Posted by djhammerd on February 19, 2014 at 20:23:48 from (173.66.69.90):
In Reply to: Super A Starting Problems posted by Janicholson on February 19, 2014 at 19:42:11:
I understand..... I will isolate the starter and use a 12 volt battery to spin it. I won't need the ballast resister.... and, if it works, it will confirm that the ignition will work with 6 volts.
THANKS for the great suggestion. I'll post the results tomorrow.
Incidentally.... I think the cables are 0. They are about a half inch thick. I also tested for resistance and there is none, at least my meter is showing 0 ohms end to end.
This post was edited by djhammerd at 20:24:35 02/19/14.
