Re: How to install vinyl decals
Posted by mkirsch on February 20, 2014 at 10:03:30 from (65.199.189.6):
In Reply to: How to install vinyl decals posted by K=Mo on February 20, 2014 at 03:56:31:
That is actually untrue, my friend.
If you just "peel and stick" it is practically IMPOSSIBLE to do large decals without getting air bubbles or worse.
If you "peel and stick" it's practically IMPOSSIBLE to hit your target spot perfectly on the first shot.
Clean water with a little dish soap to break up the surface tension will not affect the decal at all, and it will allow you to "float" the decal into place and move it around until it's absolutely perfectly aligned. The air bubbles are easily squeegee'd out.
The KEY to it is:
1. Be gentle when squeegee-ing because you will accidentally move the decal and you will have to start over.
2. Once you get it in place, and as much liquid squeegee'd out as you can, walk away. Just walk away. Let it dry, overnight.
I did Dad's Cub, Dad's Super M, and my Super H with Windex, and they're all still stuck 2-3 years later.
