Re: Block Heater for 756
Posted by IaGary on February 21, 2014 at 05:31:36 from (108.160.236.246):
In Reply to: Block Heater for 756 posted by 2510Paul on February 21, 2014 at 03:36:08:
I added a Katz radiator hose heater to a 856 years ago. It still works after 25 years.
Just bought the right diameter heater for the lower radiator hose. Then cut the hose in two.
Installed the heater with two hose clamps in the lower hose and was done.
With the heater in the lower hose the hot water rises into the engine block and heats the motor.
I believe it was a 1000 watt heater.
Gary
