Re: swapping 706 Farmall 282 for D310 engine
Posted by Baelee05 on February 21, 2014 at 06:15:09 from (12.192.13.220):
In Reply to: swapping 706 Farmall 282 for D310 engine posted by George Kramer on February 20, 2014 at 21:57:07:
While easier than going from a gas to a 310, going from a 282 to a 310 is no picnic either. You basically need to find a 706 with a 310 for a donor. You need pretty much the whole from end including fan, radiator, water pump, hood, frame rails and a lot of other little stuff. Sell the 706 with the 282 and buy one with a 310 if that is what you want. Since you have a good 310 engine the ideal thing would be to find a 706 or 756 with a really tired or blown 310 and swap in your engine. You can do the swap you are talking about, but after you are finally done you will be asking yourself what in the world you were thinking.
