Re: Play in rod bearings on 3 and 4
Posted by Matt Geisewite on February 21, 2014 at 13:15:06 from (50.192.5.190):
In Reply to: Play in rod bearings on 3 and 4 posted by CrvnJ on February 21, 2014 at 12:45:19:
Are you sure you have a std crank journal,maybe it was turned down at one time.The simplest way to figure it out would be to use Plastigauge to check the clearance and then get the proper undersized bearing.There are undersized bearings in .001 increments up to .003 I believe if it is just a worn journal. Good luck Matt G.
