Re: starter pull lever on 53 stage 1 Super H
Posted by rustyfarmall on February 21, 2014 at 13:26:30 from (208.126.186.41):
In Reply to: starter pull lever on 53 stage 1 Super H posted by SH-KS on February 21, 2014 at 08:43:28:
If you really want to make it easy, replace the starter with one from an H. The H starter has a post for the battery cable instead of that little button. Now you can install a solenoid on top of the starter, connect the battery cable to the solenoid, and then install a simple, momentary contact push button switch in a location that is convenient for you. You may need to fabricate a mounting bracket for the push button switch.
