Re: Play in rod bearings on 3 and 4
Posted by Janicholson on February 21, 2014 at 13:57:41 from (199.17.6.78):
In Reply to: Play in rod bearings on 3 and 4 posted by CrvnJ on February 21, 2014 at 12:45:19:
If the looseness is up and down (not along the journal which is OK) The journal needs to be measured and inserts used to fit the journal. Measurement must be using a micrometer, not a caliper. 6 places at angles and along the journal are to be measured. .0015 difference is Ok. Using shims under the standard bearing is also OK. Jim
