Re: Farmall 300 utility hydraulic lines
Posted by D Slater on February 21, 2014 at 17:28:32 from (184.14.211.223):
In Reply to: Farmall 300 utility hydraulic lines posted by glacier-tractor on February 21, 2014 at 07:05:14:
On later 350 tractors they started using rubber sections near the pump. Also made packages to convert 300 and 350 with solid lines to the later type to help with vibration.
One option for you is to get the pump manifold for the flex line section to mount on your pump.
For the rear get a threaded block like a 350-U diesel used, also found on some other IH stuff that bolts in place of the lines. You can then run hose between front and rear.
Manifold that goes on pump used a one inch slip on hose with clamp. Pressure side has threads that a hydraulic hose shop will have fittings to fit.
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
