Re: Is it OK to start off in 5th gear with an 'M'?
Posted by NEKS on February 21, 2014 at 19:38:40 from (138.210.244.114):
In Reply to: Is it OK to start off in 5th gear with an 'M'? posted by Patrick HMD on February 21, 2014 at 18:56:55:
You could have it at a idle and take off in 4th, then shift to 5th. That way it is not at a dead stop. The weight is moving when you pull it into 5th.
