Re: Trans./Differential Oil in a SMTA
Posted by Kevin Meier on February 21, 2014 at 21:33:41 from (208.90.10.9):
In Reply to: Trans./Differential Oil in a SMTA posted by Paul A Young on February 21, 2014 at 18:51:49:
Gear lube was used by those too lazy to fix a leak. There was a recall by ihc not to use it because it made the ta slip a
