Posted by TractormanNC on February 24, 2014 at 04:05:46 from (108.72.58.200):
In Reply to: C113 tech question posted by WellWorn on February 23, 2014 at 17:47:51:
On all U2s that I have seen, the starter faces forward in front of the flywheel instead of toward the back as in a tractor. The rear flange of the block is cast with a cutout to allow this. When a U2 block is installed in a tractor only 5 of the 6 bolts can be used as the starter cutout eliminates the use of one bolt. BTDT!
Using a tractor block as a power unit should work if you want to hand crank it or do major metal removal on the block to clear the starter.
There are flywheel housings that appear to be SAE but have never measured to be sure.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
