Posted by mkirsch on February 24, 2014 at 05:12:54 from (65.199.189.6):
We put the repaired radiator back on my "new" 240U yesterday. Installed a new thermostat. Put 2 gallons of new coolant in it, which brought the level up above the fins in the radiator.
I started it up and let it run a while. Eventually it started to warm up. Looked in the radiator while it was running. The coolant level was rising, and there was an occasional bubble.
As it got close to 170 degrees, it started pushing coolant out the overflow. Then the temperature shot up to 240, so I shut 'er down.
We did a compression check. 75 - 75 - 110 - 100.
There does not appear to be any water in the oil.
My guess is, head gasket is leaking around #1 and #2 cylinder, into the water jacket.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
