Re: super a radiator
Posted by GRAPE-DRANK on February 24, 2014 at 07:40:33 from (98.117.67.240):
In Reply to: super a radiator posted by rray on February 24, 2014 at 07:10:16:
First, does your Super A have a water pump? If not, then it is thermosiphon and you want the early-style radiator. If it is pressurized, meaning you have a water pump then you want the later style.
2nd If your hydraulics are low check your crankcase oilpan. What will happen is a seal wears out in the hydraulic pump causing the hydraulic fluid to slowly leak into the crankcase. If you were to use hytran now, that would cause the two oils to mix. I agree, hytran works well and I use it, but I wouldn't recommend it until you can rule out that hydraulic oil isn't seeping into the crankshaft oilpan.
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
