Posted by DJ in Pa on February 24, 2014 at 08:44:37 from (75.75.181.24):
Just put rebuilt carb on tractor. Starts nice and slowly gains rpms and will not idle down. I have had carb off and back on 5 times. one time it ran wild when started, other four times it starts at idle and gains rpm and will not idle down. I pulled carb down off of studs and throttle lever opens and closes butterfly. Can I check tab alignment by taking off top governor plate? Is It maybe not the tab? I bought this tractor non running so i cannot say what it ran like before.TIA
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
