Re: 450 Hydraulic Touch Control
Posted by Nick62411$ on February 24, 2014 at 11:31:42 from (216.124.141.231):
In Reply to: 450 Hydraulic Touch Control posted by Mark in Upstate on February 24, 2014 at 09:57:23:
Does the steering wheel ever seem to be "stuck" in one spot when you are driving then snap back to normal? And doe you have a stand alown power steering pump or do you run the unit off of the hydrolic system with a flow control valve?
