Re: 1086 Diff lock
Posted by pete 23 on February 24, 2014 at 11:44:33 from (74.33.90.72):
In Reply to: 1086 Diff lock posted by Russell Moore on February 23, 2014 at 08:08:43:
Couple reason they were not very reliable. The 66 series used a little dry disc clutch outside of right brake, 86 series used a better wet clutch. Both used a hollow right side bull pinion shaft with a long shaft extending through center of diff to left brake shaft. Dry ones usually leaked. Both weakened bull pinion shaft. Switch on floor board had to be held down to engage. Neither held very well under full power, when they worked.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
