Re: Farmall m almost did it
Posted by BigTone on February 24, 2014 at 14:27:23 from (70.209.131.82):
In Reply to: Farmall m almost did it posted by Nick62411$ on February 24, 2014 at 11:21:24:
A 450 head and a 450 propane manifold will help. A tune up wouldn't hurt, I'm not sure about the carb, drop the belly pump if it has one and put some money into welding up some weight bars that will bolt somewhere around the rear wheels, we have some fabricated that use the belly pump fitting holes in side of the bell housing to hold weight bars. ~Anthony
