Try having the lights on and using the starter. If the lights do not dim when the starter is (supposed to be) turning, the starter, or switch is "open". This means it is not actually getting current running through it. The next step is to find out if the switch is failing to make contact with the starter stud under the switch. (a point of failure that is common) To check if this is at fault, look at the switch and you will see a plunger that has a spring on it. If your tractor has a pull rod, the plunger will come in from the rear of the tractor towards the front. If it has a push rod to activate the starter, it will have the plunger come in from the front toward the rear. Remove a terminal from the battery and keep it from touching anything. Remove the starter switch then, if you have an ohm meter, a test of the resistance between the starter stud and ground should show Zero ohms. (NO resistance) It actually measures in the tenths of an ohm. If it has high resistance, (no conduction, meter does nothing) the starter is open, meaning it needs to be checked by a automotive electrical shop and repaired/rebuilt. It could have a broken wire, solder joint, or copper conductor inside, or it could have a hanging brush. If it has good continuity (conducts), the switch needs to be modified a little to make good connection with the stud on the starter. Use a chainsaw file or small rat tail file to elongate the mounting holes of the switch in the direction that allows the plunger to move farther toward the starter stud (about 1/8" will do). Then remount the switch and tighten so it is moved!. Then reconnect the battery, (put it in Neutral) and try it. Best of luck, Jim
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
