Posted by The tractor vet on February 25, 2014 at 07:22:13 from (75.19.125.103):
In Reply to: Solenoid posted by xrcr on February 25, 2014 at 06:23:46:
Will the engine turn over by hand?? IF it does not then the bendix is stuck in the ring gear . To un stick with KEY OFF place tractor in fifth gear and rock it back and forth HARD . When you hear a CLUNK OR SNAP it had broken free and try a restart with the key. If this is not the case then the Solenoid has burnt contacts . Sometimes you can cheat a little here as you can remove the cap on the soleniod and turn the two contact around and you can sometimes flip the disc. IF you can not flip the disc then you can clean it up with a fine small flat file . THIS IS NOT A PERMINT fix this is a BANDAID . OR you starter is plum junk and need replaced or rebuilt.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
