Re: Farmall m
Posted by John A. on February 25, 2014 at 10:03:26 from (64.128.16.238):
In Reply to: Farmall m posted by Little ky farmer on February 25, 2014 at 09:42:43:
Little ky farmer, A fresh engine Is suppose to have good high Oil Pressure. Both gauges are accurate! The engine is still tight maybe after 100 hrs or so it will lower to a more Normal level after Break-In! No Problems at all in my analysis of your description of things!
Later,
John A.
