Re: Farmall H Decal Placement
Posted by DeltaRed on February 25, 2014 at 13:15:17 from (65.100.146.210):
In Reply to: Farmall H Decal Placement posted by Matt Reinders on February 25, 2014 at 12:57:03:
There generally no 'specified' placement.The red caution is not original.Put it Put it on the tractor body next to the starter(the sticker will remain after the starter is eventually switched out)The gear pattern goes on either lightbar or rear of fuel tank(seen them both places).The oil level goes on the air cleaner bowl.The other air cleaner goes on the body of the air cleaner filter Gasoline goes on fuel tankrightside of filler where you can see from the ground.Thebig caution on left goes on the rear of the fuel tank where you can see it from the seat.The othwr warning goes on the rear of tractor above the pto.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
