Re: 1952 super m
Posted by D Slater on February 25, 2014 at 16:44:43 from (184.14.211.223):
In Reply to: 1952 super m posted by steve1243 on February 25, 2014 at 12:22:48:
Don't know, could be anything from loose wheels to bad bearings or gears. Since third and forth puts more pressure on the main shaft pilot bearing than gears more to the rear. If nothing external is found maybe check the input shaft coupling and remove the belt pulley gear box and look in the hole. Shake the shafts looking for bad bearings. Also look for metal and broken pieces. Could also be a differential or differential bearing going bad or a bull gear dragging the housing or a bull pinion bearing. Would start checking at the outside and then front driveline back first. Unless you can see a rear wheel vibrate more than usual when starting out, like a bad axle bearing.
