Re: Farmall m
Posted by pete 23 on February 25, 2014 at 18:11:13 from (173.87.146.95):
In Reply to: Farmall m posted by Little ky farmer on February 25, 2014 at 09:42:43:
See you are getting some conflicting information. A gasoline M normal high idle oil pressure is right in the 70 psi range. The diesel engines were near 45 psi. Lot of old H & M's (gasoline) had the incorrect plunger installed in the oil pump and they would run about 45 psi. I found that out the very first year (1958) that I started working for IH dealer. The problem apparently came right through the parts department. Right part number, wrong plunger. Found a few more over the years and in my own H that I bought that my dad and brother owned.
