Re: 1952 super m
Posted by mkirsch on February 26, 2014 at 05:13:00 from (65.199.189.6):
In Reply to: 1952 super m posted by steve1243 on February 25, 2014 at 12:22:48:
The clutch pedal should have something like 3/4" or 1" or 1-3/8" of free pedal travel. I can never remember which it is for which tractor. That's adjusted by that turnbuckle-looking thing on the pushrod between the clutch pedal and the throwout arm.
If you're out of adjustment, the clutch is shot anyway and needs to be replaced.
Frankly, if it's shaking that badly, and grinding, the simple cheap fixes aren't going to help you. You need to take the deck off the tractor and look down in there to find the problem.
